Re: f-12
Posted by Tom Fleming on January 19, 2014 at 16:19:37 from (173.233.18.197):
In Reply to: f-12 posted by taylorennis on January 19, 2014 at 15:13:40:
Why Mr. Kelly, good to see you finally signed up!
I agree, Make sure the gas is getting there. Also, these carbs are very finicky. When they are right, they run good. All others situations, they will drive you nuts. Worst part about the design is that the heat from the engine usually boils the fuel bowl dry when you shut them down for the day. Makes first start a wee bit of a challenge. Some of these old girls do that. some don't. your's will have it's own personality after the get it right.
This post was edited by Tom Fleming at 16:22:16 01/19/14.
