Re: Farmall M Starter Problems
Posted by old on January 19, 2014 at 18:36:03 from (209.86.226.40):
In Reply to: Farmall M Starter Problems posted by FarmallGuy1923 on January 19, 2014 at 18:28:45:
Did you before installing the new rings clean the grooves out well if you used your old pistons?? Did you also put the rings in and check end gap before installing them in the engine?? Did you also use pre-lube on all the new parts?? If you can not answer yes to all of those questions then good chance one or more is where your problem is
