Not uncommon with newrings both of your starters are probably needing to be refreshed. You know the engine is free because you turned the engine over somehow when you installed the new rings. You could pull the tractor to get it started and get it running after a good warm-up then your starter mite work. Is the battery up to snuff and are the cables and the sw up to snuff. I find the same problem sometimes after a new engine is finished. You also could use a 12v batt to start. You know the engine is free cause it does turn oever just not fast enough to start.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
