Re: Farmall H Magneto Timing
Posted by El Toro on January 20, 2014 at 13:50:16 from (96.244.7.206):
In Reply to: Farmall H Magneto Timing posted by Reinders on January 20, 2014 at 08:41:10:
Remove No1 spark plug near the radiator and bring that piston to TDC on the compression stroke. Then remove cap on mag and see where your rotor is pointing. It should be at the No1 plug tower that's about one o'clock. If it's way off you need to pull the mag and rotate the rotor to the one o'clock then reinstall it. It should be pointing to your No1 plug wire tower on your cap. Hal
