If it is a wire, it can be replaced with a discrete (cheap) 1965 chevy bellair 6 cylinder resistor. Just wire it with 12ga stranded copper from the ignition switch I terminal (now going to the coil)the copper wire and resistor are in series with each other and connect where the existing resistor wire is connected. If it has a discrete resistor, the chevy resistor can be a direct replacement. Jim
