May be some crap under the return check valve which is set to open at 40 to 45 psi, same as the regulating valve in lift pump. Check valve is under the nut, and possibly snap ring and disc on top end of pump. lift pump relief valve is under the cover on rear of lift pump. Broken spring, stuck valve same problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
