Re: Case IH Temp Gauge
Posted by JimB2 on January 20, 2014 at 19:28:11 from (99.240.243.222):
In Reply to: Case IH Temp Gauge posted by DanMD on January 20, 2014 at 19:00:29:
Hi Dan, a simple explanation:
The boiling point of water varies with the
atmospheric pressure. Atmospheric pressure is
depended on how many feet above sea level you live
at and the barometric pressure. This is the reason
that all modern rads are pressurized to keep the
boiling point higher and more consistent.
So when the sensor part of the gauge is installed
in the MD which I believe would have a pressurized
rad cap the boiling point would be up in the RED
on the gauge.
I had to explain the same thing to a daughter that
moved to Salt Lake City, UT that is about 4200 ft
above sea level. She complained it took so much
longer to cook potatoes versus where she used to
live at 400 ft above sea level. In Salt Lake City
the water boils at a lower temperature therefore
since the temperature is lower it takes longer to
cook the potatoes.
Hope this explains the temp gauge reading.
JimB
