Re: negative ground
Posted by MN Mike on January 21, 2014 at 06:31:58 from (216.77.154.39):
In Reply to: negative ground posted by henhawk1969 on January 21, 2014 at 06:19:13:
yes. everything is backwards and needs to be switched/repolarized. search the archives for what you need to do.
