Re: negative ground
Posted by gene bender on January 21, 2014 at 11:11:57 from (207.177.56.213):
In Reply to: negative ground posted by henhawk1969 on January 21, 2014 at 06:19:13:
Yes you need to change the regulator if you have a cut-out it will be ok but the reg is made for pos gnd and will probably say so on the bottom of the reg as those were marked such. You will also need to change the leads on the amp guage just keep it pos gnd and then mark it so you will remember as there isnt any reason to change grounds.
