Re: negative ground
Posted by old on January 21, 2014 at 12:21:59 from (209.86.226.27):
In Reply to: Re: negative ground posted by sflem849 on January 21, 2014 at 11:46:57:
Ya the ones you have to hook to a battery can do funny things if you hook them up wrong. As in the + clip and the - clip back wards. Now if you hook it up + to + and - to - what ever ground the machine is should not cause any problems
