The other ideas are fine. I would start with the linkage from the hand lever to the governor. It should provide a full travel to the governor input lever as the hand lever moves from idle to full throttle. If not make it so. The linkage can be disconnected at the governor and moved by hand to assure it is in the governor, and not the operator side linkage. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
