Easier yet look at the slots up by the levers where the numbers are for the gear locations. If the slots the levers don't line up somebody has got it out of place there . It's a common thing if the linkage is worn loose. If that is not the problem then as Allan has explained. It is the roll pin at the bottom of the shaft. I suspect the linkage since you labor the engine when you try to move as it is in 2 gears at once. If you keep trying you will change some gears inside after you break them
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
