Re: Update on H
Posted by Jim Becker on January 22, 2014 at 07:43:13 from (173.71.58.166):
In Reply to: Update on H posted by Dave8N in Pa on January 21, 2014 at 15:26:37:
Quoting Removed, click Modern View to seeAfter you get the broken parts removed (so the transmission is not connected to the clutch/engine), put it in gear and try turning a rear wheel. If it is locked up, you haven't found the root problem yet.
