Re: farmall a head
Posted by CharlieNJ on January 22, 2014 at 11:42:42 from (76.117.68.151):
In Reply to: Re: farmall a head posted by buggsy on January 22, 2014 at 10:41:05:
I suggest you leave the "bolts"(studs) alone, unless you need to have the deck milled for some reason. The studs are not always easy to remove without bending them, or drawing the threads out of the block when replacing them. Take the nuts off of the loose studs, and screw them into the block before installing the head.
As to the "nest", blow it out with air as well as possible for now, then wash it through with a garden hose from the upper water outlet after you have the head back on. Maybe seal off the lower outlet and give the block a vinegar treatment later.
