Re: How To Remove The Axle In The Final Drive On A Cub
Posted by Gerry Powell on January 22, 2014 at 16:53:37 from (173.172.83.6):
In Reply to: How To Remove The Axle In The Final Drive On A Cub posted by KCTractors on January 20, 2014 at 15:17:39:
Or a press if you have one.Getting it to move at first takes some good force on some but not all. Don't loose the small shims between the inside bearing and the spacer, easy to miss in the grease and oil. They have to be put back in to properly pre-load the tapered bearings.
