Re: HELP! 454 hydraulics
Posted by T_Bone on December 16, 2000 at 03:59:50 from (207.254.53.42):
In Reply to: HELP! 454 hydraulics posted by kirk on December 15, 2000 at 17:03:39:
Hi Kirk, along with what Lee said, look for a plate about 10"X7"X 3/4" with steel or high pressure hose coming from it, probablly two or more lines. Some pumps bolt to the plate and the center bolts is what holds the pump to the plate and the filter sets behind the hydraulic pump. If this is the set up you have, You will have to start the pump out before removing the 4 pump bolts then finish removing the plate.
T_Bone
Post A Followup
: Re: Re: HELP! 454 hydraulics
