Hi FB--- If you please, I'd like to share a a few things with you concerning your power steering. This may not be of any benefit to you , but maybe to someone else reading this and considering adding on a power steering unit to their tractor.
This is what came with my M when first bought. The dogleg is clearly seen between the motor and the front steering shaft due to improper alignment by the previous installer due to ignorance or not caring about it. Could have been enough out of center to cause an oil leak in the motor due to stress. The coupling joint is sloppy and worn due to oscillation when the steering shaft is turned, causing a lot of backlash at the steering wheel. So proper alignment is critical.
And it worked just fine, but very sloppy for obvious reasons. Then, the oil leaks. The pump shaft was leaking out the front, and the torque motor also leaking rather bad. This caused the wind from the fan to blow leaking oil all over the motor. Not good, rather messy. I finally understood why the pump had been disabled. I went a little further and yanked the whole unit off, not wanting to worry about anymore leaks. I just didn't want to deal with it. It's cleaner, leak free, and not that hard to steer. I justified this by thinking that if grandpa got by without it, I can too. lol
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event
... [Read Article]
Latest Ad:
[More Ads]
