Farmall H Lift-Cylinders
Posted by MRF-Engines on January 25, 2014 at 18:35:50 from (75.89.151.143):
Hello all again. Had an issue with my plow setup this morning. The plow would only raise up about two inches and act like it was binding up. I determined it was the cylinder, thinking it may have froze up some with this cold weather. So after I brought it in and warmed it up, I pulled it apart and found oil had leaked by the piston seal and was not letting the cylinder go all the way.
Is it still possible to get a new seal for the piston for the one-way lift-all cylinders? I got two of these, the one I am using and one that is locked up. Would be nice to have the both. Thank you,
