Re: 350 u fork lift rig
Posted by Janicholson on January 25, 2014 at 21:36:25 from (74.60.94.18):
In Reply to: 350 u fork lift rig posted by 300dave on January 25, 2014 at 18:32:26:
I cannot tell you what the fork system will lift (rating0 I can tell you that the tractor can handle enough weight to near flatten the tires. We pulled a well casing with a 350 FH drawbar (we chained to both prong sockets, not the middle of the drawbar)
That 60 foot well casing came out with 3 inch balls of crust and scale on every joint. The well came out easily in the sense that we had little actual physical effort other than cutting off the casing at the couplings. Jim
