The throw-out bearing rides on a tube and sure does need to slide when the clutch is pushed in its froze because of no lube spray with some stuff be careful you dont want to damage that tube it is a pressed fit into the bell housing. The rod that goes thru the bell housing and holds the assy the bearing mounts to needs to be removed that will help removing the throw-out bearing as that assy will need to come off that tube for replacement
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
