Re: Sawmill thoughts
Posted by gene bender on January 26, 2014 at 19:59:59 from (207.177.56.213):
In Reply to: Sawmill thoughts posted by Lucid on January 26, 2014 at 14:12:04:
The SC will run a sawmill with a 4ft or so blade if you are going to saw realy big stuff you would want more HP Just what dia logs would you be sawing
