Re: What kinda shifter is this on this Farmall M
Posted by jasinpa on January 26, 2014 at 20:38:44 from (67.234.166.174):
In Reply to: What kinda shifter is this on this Farmall M posted by kossuth on January 26, 2014 at 09:06:30:
lever is for an M&W 9 speed added to trans , have one on an H but dont have that syle handle, you can tell by where it hooks on trans case it an older syle, new style uses a cable in from front of case , wont change pulley speed but will raise PTO speed & hyd. pump speed , the way these work just gives you more speeds between 4 & 5 (road gear) all lower speads are the same , also that live PTO kit is nice but most leak oil on brakes & good luck finding clutch disks when they start slipping more of a collectors piece today
