Re: Sawmill thoughts
Posted by Brownie 450 on January 27, 2014 at 04:45:18 from (66.43.241.198):
In Reply to: Sawmill thoughts posted by Lucid on January 26, 2014 at 14:12:04:
My brother inherited a Wood Mizer band saw mill, & it has a 12 HP. Kohler engine for power. It will cut 32 inch logs 16 feet long. The length limitation is somewhat limiting if you would want 20 foot lumber. Nice outfit---pull it to where the logs are.
