Re: holes in hood
Posted by rustyfarmall on January 27, 2014 at 11:26:43 from (208.126.186.41):
In Reply to: holes in hood posted by Rat in nb on January 27, 2014 at 11:20:23:
The hole is for the filler neck on a small. gasoline starting tank. Either your tractor was originally a distillate fuel or kerosene burner, or the hood is from one of those tractors. Check the serial number. If the serial number has an X1 suffix, it came from the factory equipped to burn gasoline, and should not have the extra hole. If the serial number has NO suffix, it was originally a distillate fuel burner, and SHOULD have the hole.
