Re: Farmall h governor
Posted by sony224422 on January 27, 2014 at 14:34:46 from (198.228.200.173):
In Reply to: Farmall h governor posted by David G on January 27, 2014 at 14:19:36:
I think I am confused by timing.. I set tdc and took the distributor off turned the shaft until the rotor pointed to 1 and put it back on. Wouldn't start. So I took the cap off again and it was pointing 180 from 1 on tdc. Put it back how it was and it fired up.
Timing from ear might be what I have to do along with playing with carb settings.
It should be able to take off in 5th gear shouldn't it?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
