Re: Loader For 300u
Posted by jeffcat on January 27, 2014 at 19:32:06 from (173.72.26.60):
In Reply to: Re: Loader For 300u posted by AJB-830 on January 27, 2014 at 18:47:17:
You are dead on about steer when moving! The loader you have is the same one on my tractor. The power steering unit has a hidden oil plug up under the dash board wrap around shell near the back of the unit. You MUST find it and put some hi -tran in it!!!!!!!!!!!!Slowly your steering unit will rip itself apart. It runs out/dry and then one day it don't steer. I think this is on the factory units. Go to the left side of your tractor and squat down a little. Just in front of the battery look about an inch or two down and then a couple of inches toward the front of the tractor. I think it is a 9/16 square plug. FILL IT!!!!! Jeffcat
