Re: Hydraulic cylinder rebuild
Posted by shadetree operator on January 27, 2014 at 20:28:47 from (24.245.94.20):
In Reply to: Hydraulic cylinder rebuild posted by Bkpigs on January 27, 2014 at 18:39:53:
Bkpigs To take your cylinder apart, chuck it in a vice, then turn the cap end while looking through the rectangular hole in the side until you see the ends of a square ring. One end will be bent down into the cap,the other end will be loose. Bend the loose end up then turn the cap to roll the ring out. Then you can twist the cap out of the barrel then the rod and piston. The rest is just finding the o-rings and seals and reassembling.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
