Re: More 706 trans mystery parts
Posted by Jim Naden on January 27, 2014 at 22:53:22 from (75.219.208.219):
In Reply to: More 706 trans mystery parts posted by 4010wy on January 27, 2014 at 20:31:55:
The e-clip probably came from the detent arm pivot.
It's advisable to run a safety wire through the multi roll pin that locates the shift cam to the shift shaft. Mechanics wire is acceptable to use. Keeps the pieces of the pin in place.
If you find any slop in the reverse pivot arm where it passes through the cover get that fixed now while you are apart. A little slop there leads to poor reverse engagement.
The shift rails have been known to fracture at the bolt hole. Might give that a look.
This post was edited by Jim Naden at 23:41:15 01/27/14 3 times.
