Posted by D Slater on January 28, 2014 at 04:34:00 from (184.14.177.12):
In Reply to: Re: Farmall h governor posted by Janicholson on January 27, 2014 at 11:58:01:
Jim unless the H pulley was changed or marked later there will only be double marks close together or one mark at TDC. With double marks the first to pointer on # 1 compression stroke turning crankshaft normal rotation is TDC. If the pulley also has a mark to locate the pilot grease fitting in the flywheel it will probably have the double marks to ID from the grease locater.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
