Well your in there now so now is the time to repair all the sloppy pieces and parts . If you have not removed the side cover over the rev. shifting fork now is the time to do so . This allows you to get the Rev. shift rod back in to the shift fork . IF that shift rod has a sloppy key way now is the time to fix it . The main reason for all those broken pieces and parts is someone was slam shifting it due to improper clutch and dump valve adjustment . When everything set set correctly they will shift with two fingers and NO SLAM SHIFTING is required .
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
