Re: '48 Farmall Cub
Posted by old on January 28, 2014 at 09:28:36 from (209.86.226.58):
In Reply to: '48 Farmall Cub posted by RAN M on January 28, 2014 at 06:29:04:
To really get it clean yes you have to pull it off the tractor and let it soak in gas or other such thing. Yes you can try taking a few cans of carb cleaner spray and spray it out but that can also be hard on the paint and maybe even remove some of the paint
