Re: Engine Unlocking Tips
Posted by 504 on January 28, 2014 at 19:47:46 from (199.127.54.155):
In Reply to: Re: Engine Unlocking Tips posted by farmallguy1923 on January 28, 2014 at 19:34:55:
ATF is as good as anything,after a few days of soaking smack each piston with a block of wood and a good sized hammer. Soak some more repeat. I like to use a pipe wrench on the lower crank shaft pulley to turn the motor. Most pulleys you can turn the wrench 90deg and hook the jaws in the center and outside of the pulley.
