Re: Engine Unlocking Tips
Posted by dej(Jed) on January 29, 2014 at 05:11:11 from (141.189.113.1):
In Reply to: Engine Unlocking Tips posted by FarmallGuy1923 on January 28, 2014 at 18:56:44:
Before you do anything remove the oil drain plug and check for water. If water or antifreeze is showing then save yourself some grief and tear it down. If it doesn't show water then fill the cylinders with some solvent, oil and wait. If it turns you might luck out and get it running okay. Most of the time however the rings will also be frozen to the pistons and you will have to tear it down anyway. I have freed many a stuck engine by removing the head, sanding the cylinder walls, adding oil and smacking the piston top using a 10 lb sledge and a piece of oak block.
