Do you have the auxiliary reservoir in the loader frame filled and connected to the touch control? The touch control will run out of oil at about 3' off the ground due to the one-way cylinder if it can't get oil from the auxiliary reservoir in the loader.
There may also be a procedure for bleeding the line from the auxiliary reservoir to the touch control, because it has to "suck" the oil from the auxiliary reservoir. If you put the connecting line on dry, it may not be able to pull in oil from the auxiliary reservoir.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
