Could the lift cylinders seals be worn internally and leaking? Does the bucket stay up? If the seals are bad the bucket will settle back to the ground (unless the hydraulic system has a check valve in it) So if it does settle back down its a pretty good indicator for you of bad lift seals.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
