Re: Torque tube problems
Posted by Janicholson on January 29, 2014 at 06:07:01 from (199.17.6.25):
In Reply to: Re: Torque tube problems posted by The tractor vet on January 29, 2014 at 06:02:24:
The Vet is on top of this. I only use the inserts as they are fully machined threads, not a "spring" Many options for repair. If the holes are not drilled into the interior of the case, don't allow your drill to go through either. If it is into the case, use a vacuum to pull chips out of the hole to prevent internal contamination. Jim
