Ok the cylinders are the same cylinder and yes it holds postion fine and doesn't settle. I did fill the line from the TC to the loader resevour and it seems to be cycling becasue the line will get warm to the touch I am assuming becasue the hyd fluid is running through it. I do suppose it isn't pulling it through and the TC is using its hyd fluid and lifts untill it is empty and then stops raising the bucket? Could I shut the tractor off open the TC resevour and more Hydraulic oil and if it lifts then it would not be getting oil from the sump to the TC? Maybe I am looking at this wrong I am thinking of the low suction line from the top of the sump tank on loader to the TC. Is it possible I have a restriction on the hard pipe from the spool to the buttom of the sump and it is not putting hyd oil back to the TC?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
