Re: Farmall 656 Frame Rails
Posted by steve_in_mo on January 29, 2014 at 13:16:37 from (168.166.54.11):
In Reply to: Farmall 656 Frame Rails posted by GR Gold on January 29, 2014 at 12:34:06:
You'll probably need to cut and weld frame rails to put in a wider engine. The design with frame rails at the front of the bell housing goes back to the letter series tractors and through at least the 1206. F-20's had frame rails outside the bell housing but they went back to the axles.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
