Re: 200 Zenith Carb problem
Posted by HUD on January 29, 2014 at 16:13:38 from (69.4.195.14):
In Reply to: 200 Zenith Carb problem posted by HUD on January 29, 2014 at 08:37:10:
Thank you for the quick response. I have owned the tractor for several years with no issues. Only recently did I have a problem I.e. engine running wide open with no throttle response. Stub of the screws are still in the throttle arm so plate clearly was in a bind and broke off. I will pull the intake manifold and see if I can find. One cylinder not firing so I expect that is the issue. Thank you
