Re: crank removal
Posted by El Toro on January 29, 2014 at 17:18:30 from (96.244.7.206):
In Reply to: crank removal posted by Rustyone on January 29, 2014 at 15:04:18:
It may be easier to pull the crankshaft by removing the cam shaft. You may need new cam bearings and it would be easier to retime the two gears by installing the crankshaft first. If you're having the block hot dipped make sure any pipe plugs that were removed on the oil passages are reinstalled. Sometime we forget to reinstall them and you won't have any oil pressure. Hal
