Farmall 400 question
Posted by DK44H on January 29, 2014 at 17:36:03 from (96.31.177.224):
I ran across a 400 farmall today and it was a factory T/A delete and only had two remote levers on the console instead of three. Would this kind of set up be fairly rare? Or not really? I've always seen them with a T/A even tho I know that a delete was an option but I've never seen one with less than three remotes. This one is completely stuck, engine and gear shifter won't move, but the tin work is beautiful as are the emblems and tach. And the seat is tight. I'd like to pick it up if I can. Going to work on it this weekend. Thanks.
