Posted by Paul from MI on January 29, 2014 at 18:08:20 from (204.106.248.120):
In Reply to: what is this for?????? posted by Ron in nb on January 29, 2014 at 11:35:57:
Shutters were used on lots of older tractors to maintain coolant temps hot enough to burn kerosene or distillate. Simplest of them wee just curtains that blocked air flow thru the radiator. Later on the were changed to vane types that could be adjusted from the tractor seat so you didn't have to stop and get off to adjust the shutter. The vane types were notorious for sticking and rusting fast, so lots of them were removed especially after most started using gasoline instead of distillate. The crank you refer to was used to adjust the radiator shutter. It's almost certain that your tractor was originally built to burn kerosene or distillate.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
