Re: Farmall 656 Frame Rails
Posted by GR Gold on January 30, 2014 at 07:02:05 from (75.88.239.30):
In Reply to: Re: Farmall 656 Frame Rails posted by Owen Aaland on January 29, 2014 at 15:24:08:
Does that mean that 966 or 1066 rails would bolt up to the bellhousing the same, only they would be longer?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
