Re: 7mph 4th gears for farmall m
Posted by D Slater on January 30, 2014 at 16:37:00 from (184.14.177.12):
In Reply to: 7mph 4th gears for farmall m posted by zanslastclu on January 30, 2014 at 12:46:08:
I-6 4th and 5th slider won't work for 5th speed on a M input shaft. M locks onto 20 teeth and the I-6 locks onto 23 teeth. If you use the I-6 transmission input shaft it uses a different constant mesh gear than a M. That speeds all gears up along with the PTO speed. Sixes use a ring and pinion that gives faster ground speeds in a M. But if you need a standard low gear ground speed you won't have it.
Try a 9 speed transmission. They speed the PTO also in high range. But for raking hay if you happen to use a PTO rake, placing tractor in a gear that will go 7MPH or faster and running less RPM will work for the PTO and use less fuel. For a ground driven rake no problem.
