Looks likeroller of shifter. Fixed neighbors 706 with broken shift rail last year. Got shaft from dealer it is updated uses c-clips to hold fork to rail instead of bolt. You can modify shift fork by cutting ends down so clips fit on shaft. Also I updated the park lever with IH kit with spring loaded shaft. It locks and holds tractor better which makes it safer.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
