Re: H Radiator, what's this tube for?
Posted by GordoSD on January 30, 2014 at 19:41:05 from (216.106.251.211):
In Reply to: Re: H Radiator, what's this tube for? posted by neblinc on January 30, 2014 at 17:41:54:
Randy, as long as you have that rad cleaned, try a little 400 sanding, 800 sanding and 1500 buffing. You have polished brass tank. We did our Ford hot rods back in the fifties for a cool look.
