Re: 7mph 4th gears for farmall m
Posted by farmallhal on January 30, 2014 at 19:55:09 from (76.2.171.233):
In Reply to: 7mph 4th gears for farmall m posted by zanslastclu on January 30, 2014 at 12:46:08:
Ditto on the 9 speed making a very useable tractor. I have Heisler 9 speeds in both a Farmall H and M which make them very helpful with a number of tasks. As mentioned in another response it also speeds up the PTO and belly pump so you have to be careful there if either are engaged. I have disconnects for the belly pump on my tractors when in high range. The M&W or Heisler neither one affect the original and standard 5th gear. They add four more gears between the original 4th and 5th gears. You end up with a 4th gear in high that is about 12 mph with a lot of pulling power for heavy loads. They are fairly common and for sale frequently so they are out there. I saw some fast 4th gears at times for sale in the classifieds in Red Power Magazine in the past. Justin Weber would be a person to contact as well. Good luck with your projects, Hal.
