Re: farmall a steering
Posted by gene bender on January 31, 2014 at 01:58:23 from (207.177.56.213):
In Reply to: farmall a steering posted by pgo12 on January 30, 2014 at 23:56:05:
No but i have found a complete tear down and replace the bad bearings and bushings along with new seals you will have good steering again. Be sure during repair you get grease to the bottom of the spindles with front wt of tractor grease wants to come out the top so have the wt of the tractor off the spindle and you can get grease to the bottom area. I have 3 As and have repaired other front assys do your work correct and you will end up with good results fill with 90wt after repairs are made and it will last you well.
