Re: 650 diesel governer
Posted by n9lhm on January 31, 2014 at 06:33:07 from (199.8.48.226):
In Reply to: 650 diesel governer posted by 450dieselfan on January 29, 2014 at 20:54:49:
If that is a B series pump (no scavenging pump/return to the tank but a bottom sump drain instead), and that drain plugs up and fills the pump with fuel, it will do strange things like you describe. Run a wire up through the drain and make sure it"s clear so the leakage fuel from the distributor valves can escape and see if that makes a difference. E-mail is also open.
