Re: 756 Farmall Hyd Reroute Piping
Posted by Loren in MN on January 31, 2014 at 08:06:23 from (75.168.61.103):
In Reply to: Re: 756 Farmall Hyd Reroute Piping posted by mkirsch on January 31, 2014 at 05:18:19:
The hoses cut correctly thing was my first thoughts, but agree that they must be the correct length, so I thought with a little trial and error I could trim and re-trim the steel tubing until I got the correct length. If the tubing didn't work, then I could always use hoses. I did do a small amount of bending on the tubing but in such short pieces it was hard to do without kinking the tube. Also, tight bends aren't good for most hoses available today.
